Fan Connectors on Motherboard
Feb 19, 2018
4
I am thinking of upgrading my motherboard, RAM and Cooling in my PC, I am thinking of getting an ASRock motherboard, the specs say it has:
1 x CPU Fan Connector
1 x CPU Optional/Water Pump Fan Connector
2 x Chassis Fan Connectors
1 x Chassis Optional/Water Pump Fan Connector,
I am thinking of getting 3 fans for my case, and 1 Liquid CPU Cooler, would I be able to connect all of my fans and my cooler to my motherboard only?
CPU Cooler: Cooler Master - MasterLiquid 240 66.7 CFM Liquid CPU Cooler
Fans: 3 x Cooler Master - SickleFlow (Red) 69.7 CFM 120mm Fans
My Current Build:
Case: Bitfenix Aegis Core
Motherboard: ASRock Z270M Extreme4
CPU: i7-7700k 4.2Ghz
GPU: Gigabyte 1060 GTX Mini Itx 6GB OC
HDD: Seagate ST1000DM010
PSU: Standard 500W Matx
1| Please list your proposed system build like so:
CPU:
Motherboard:
Ram:
SSD/HDD::
GPU:
PSU:
Chassis:
2| We'll be able to verify if you actually need that many fans for your build. Speaking of which, please state the cooler's make and model.
I have officially updated my post, adding the specs you requested.
