Question Fan controller smells like alkaline battery is that normal?
Oct 16, 2022
I bought this fan controller because i cant plug more fans to my mobo, so i plugged 5 rgb fans directly to psu to power them up, but after 2days my pc shutdown and never start again, found out that my psu died so i ordered a new psu after that i checked my pc components and i smelled something like a leak alkaline battery in the fan controller i checked the inside and didnt see any burn marks, so should i still use the fan controller or should i buy a new good one?
Not normal. Odors in electronics are a result of heat (usually too much heat) and indicate problems that may not end well.
Update your post to include full system hardware specs and OS information.
PSU(s): make, model, wattage, condition for old (how old) and new PSU.
What make and model fan controller?
What make and model fans?
I would not reuse a fan controller that had a "smell" to it
You do not need to see burn marks to have something failed or damaged.
Reactions: CookieRanger
Bought a bnew corsair 750w 80+ bronze coz my old 600w 80+ bronze psu died when i plugged those 5 rgb fans directly to psu, my spec is
I5-7400
H110m-f
8gb ram
1 ssd 128gb and 2 hdd 1 tb and 4tb
Rx 580 8gb
And will be directly plugging the 5 rgb fans to the psu and yes I'll do what u have just said I'll not use the fan controller, even if there's no burn marks, i thought it was just normal for the controller to smell like that, the store where I ordered it probably gave me a cheap one, thanks for the advice u have given sir
