Hey ![Smile :) :)](/data/assets/smilies/smile.gif)
Awhile back i built my first PC (thanks to you guys)
Recently there were some issues with the GPU overheating so i upped the GPU fan speeds (again, suggested by someone here) And i also decided to buy some extra case fans which i could not afford before. So i was wondering if i should also buy a Fan controller, it is worth it or just eye candy? also which make would you recommend that I buy? (under £30 pref)
thanks
thanks
