G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi,
My manual for the Asus P4PE mainboard specifies the following for
connections to fan headers.
"The fan connectors support cooling fans of 350mA-740mA (8.8W max)."
The fan that I have selected for the cpu header is the Vantec (T9225)
Thermaflow which is variable speed with a maximum current draw of 260mA.
My questions are;
1) What is the significance of the lower 350mA Asus spec, above, as it
relates to the 260mA fan that I want to install.?
2) Given the appropriate selection of a fan to match the heat production
of a given cpu (in this case the Intel Pentium 3.06 533Mhz) is there any
overriding problem using a variable speed fan with a cpu (either with a
header or directly to a power supply?.
Thanks for any help you can provide.
Hi,
My questions are;
