[SOLVED] fan info in hwinfo64
n9mfk9
46
Hi all
I am running afterburner it gets fan speed from hwino64 but if I look at hwinfo64 osd rts I do not see fan info
I like to just use hwinfo ods and not use afterburner
my system is
CPU: Intel i7-6700K
Motherboard: Asus Z170-K
thanks, Beau
Rainmeter has "gadgets" that can display info given to it from HWINFO (example). I don't think Rainmeter can provide info to HWINFO like Afterburner can, if that's what you mean. So basically I would pull Rainmeter out of the mix.
well, i can see the fan speeds in HWINFO so it does collect info but I am not sure about the osd rts part?
I normally use Speedfan to track that but I don't use it with an OSD
I can see rainmeter can use HWINFO plugins to collect the info, @gardenman might know more about that though
From what I can understand of the question, you want to use HWINFO for OSD. You want to see the fanspeed from Afterburner on the HWINFO OSD.
The problem is, most info out there is how to display info from HWINFO on the Afterburner OSD, like this video.
It makes it difficult for me to answer since I don't use either HWINFO or Afterburner.
