Removing the fan is the only option.
what can I do about this? Removing the fan isn’t really an option because I’m kind of rushing to finish this build
removing the fan is the only option
Can't tell if you will have enough room to remount it after the power plug is installed without cutting that mount off.
I moved the fans over so that it isn’t blocking it anymore, would that affect anything else?There are so called 'slim' fans. They have lower height then standard ones. Slim fan should fit there. Otherwise - removing fan is the only option
Should be fine.I moved the fans over so that it isn’t blocking it anymore, would that affect anything else?
