Images here for a visual:
View: https://imgur.com/a/5N9yHSH
Hi guys, please help! The fan that came with my case lights up but will not spin. No case manual was provided or can be found online. I have contacted the case company (Gamemax), to no reply.
There is one RGB 3 pin connector (image attached) that is not plugged into the motherboard as I do not understand how this goes in and if it is necessary.
I am also under the impression that this connector is for powering the LED and may not be related to having the fan spin.
If this connection is required, the places I have on my motherboard are shown in the attached image - where would it fit?
(I wonder if I need an adapter of some kind)
The power for the fan hub is connected via molex to the power supply (see image).
Thank you,
Grellow
Thank you,
Grellow
