Fan makes horrible noise at high rpm
TommyFamzy
301
When one of my radiator fans goes over 1680 rpm it makes a horrible sound, almost as if the fan bearing is going or something, should i buy a new fan or is there a fix?
If you've only had it for a few weeks it was probably faulty, you should still be able to get a warranty replacement. Corsair makes some of the best fans out there and they have great customer service. You should probably be able to get it replaced quite easily.
i got a full black and yer setup sp120's would look BOSS, but that thing about only within a certain rpm range, is that wierd at all?
Honestly no clue mate, just in the last couple of days one fan makes a wierd rattling/grinding/scratching sound, when i go above 1680 rpm, but at 2000rpm it doesnt make the noise.... i just assumed it was the bearing only thing i can think of no wires obstructing it or anything
