Fan on the right side of my Legion Y540 started stopping abruptly only to restart and repeat the process every couple of seconds. I couldn't capture it well in the video, it usually runs for 2-3 seconds before stopping with a "brrt" sound and it's getting extremely grating. I have removed and cleaned it thoroughly so no issue there, it looks exactly like the left fan which is working perfectly so I assume it's either:
-Short circuiting or other wiring issue I can't fix
-(hopefully) some missing driver I can download or something since my laptop wasn't touched in the few hours that it went from being absolutely fine to this, but I think there was a Windows update
In case it's the first, is there a way to disable only this fan? It's going to be a while until I can get it fixed and it's not cooling anything like this anyways.
Thank you.
