Optiplex 7010 MT 0GY6Y8
Intel Core i7-3770K
Zotac Nvidia 1080 Ti Mini
Corsair Vengeance Pro 32 GB
Samsung 850 Evo 500 GB
Kingston A400 120 GB
WD Black Performance 6 TB
EVGA Glacier 650W Modular
So I took my computer apart the other day, and cleaned everything. This included underneath the motherboard, Hard Drives, Fan blades and vents, etc.
Well, I put the only case fan on this machine on backwards, so now it's an intake fan. I would have taken a picture, but I feel it's better for viewers to see where the fans are blowing air...
The current Orientation:
https://ibb.co/gJdD9z
A picture of a Dell Optiplex 7010 motherboard in chassis:
https://kbimg.dell.com/library/KB/KNOWLEDGE_BUNDLE_GROUPS/ESUPPORT/7010MTcover4.JPG
As you can see from the terrible paint picture and an actual picture of the system, the only way the case can breathe is now through any holes in the chassis. My temps seem normal for the most part, when gaming the GPU always runs a little hotter than I'd like, but it is SFF so it's to be expected. So my question is, do you think this will be an issue for the other components where the air might be sitting longer? (RAM, HDD/SSD, etc.) This way probably keeps hot air in longer.
Another thing to note:
The fan comes attached using little rubber pieces that are big on two ends and skinny in the middle, meaning, when you want to remove the fan, they get broken. No screw fits the holes as replacement. Right now I have zip ties on to hold it in place, but do you think I should swap this back around?
Basically - it's either in or out.
Intel Core i7-3770K
