Hi,
I recently upgraded my pc by installing a new AIO, specifically the Liquid Freezer 2 280mm. My case is the Gungnir 110M and the AIO can only fit in front. After watching countless videos about LFII, I was pretty sure, despite its radiator thickness, it would fit in front, as long as I moved the HDD tray back. However, it didn't fit. What I did was I removed the dust filter that came pre-installed in the case and replaced it with the AIO fans.
This is the pic: View: https://imgur.com/a/vTnf7nf
Since I do not have any dust filters anymore, is there anything I can do to minimize the dust entering via the front panel? The dust filter really helped a lot.
Would it hinder the airflow if I just add those black magnetic filters (those usually come pre-installed in other cases that are put on top) and just stick it in front of the fans?
Any help is appreciated. Thanks!
