[SOLVED] Fan positioning for RHINO PC
Feb 10, 2019
Hello.
So I bought this "Rhino" PC Case and I don't know how to place fans for maximum cooling.
Please help, I cannot find any solution on internet and I cannot even find this case anywhere.
Are you sure both front and top are intake? Thats pretty amateur assembly if it is.
Anyway, if the top ones are truly intake then reverse them so they become exhuast and then youre fine.
Read here for a good Q&A on fans and positioning:
https://www.howtogeek.com/303078/how-to-manage-your-pcs-fans-for-optimal-airflow-and-cooling/
Typically cases are set up to pull in from the front panel and pull out through either roof or back panel exhaust vents, but I can't tell you exactly where to place them unless you provide your exact case model or link an image(s) of it.
