I recently installed a Coolermaster ML240L on my computer ( not needed but buddy had one and never ended up using it and sold to me for cheap)
I have noticed though that the fans keep jumping from around 550rpm - 871 and then back down. The Ysplitter is hooked up to CPU fan on the MOBO, and pump is hooked up to System Fan slot
(The pump seems to be running fine)
i have a lenovo MOBO with no Fan Control Bios, and have tried numerous Fan Control Softwares to try to adjust them with no luck..
Ive got a I7 4790
RX 580 Graphics card
Lenovo Sharkbay Nok Mobo
16GB of Ram.
I have tried changing the slot the fans are hooked up to, Reversed them from CPU to System Fan, and even AUX Fan1 slot.
Any suggestions or ideas to solve this issue?
Ive got a I7 4790
16GB of Ram.
