I will be building inside a Corsair Air 240, and my mobo only has a single 4-pin case fan header. Other components are i3-6100 with Cryorig C7 and an MSI 950 single fan, nothing overclocked.
I was thinking of using a fan splitter and placing just two fans in the case, one intake and one exhaust. Example: http://i.imgur.com/W4PlZSc.jpg
Another possibility would be to place both fans as front intakes. But I've been told to always have at least an intake as well as exhaust.
This case has very good airflow with filters and the other components shouldn't be generating too much heat, right? So will 2 fans for the whole case in either setup be enough? I am trying to avoid to third because the third will have to be powered by psu, which would make it run at full blast.
Thanks in advance!
Thanks in advance!
