Fan Setup Questions
MadPhrog
9
I am making my first computer and as the title says am wondering if i have the fans set up right. I have a Fractal Design R4 case. I have one 140mm fan and one 120mm fan as an intake in the front, and one 120mm intake at the bottom leaving the 140mm stock fan as the only exhaust at the back. Will this setup work or should I re-arrange it, thanks.
@Madphrog Your front intake setups are just fine. Well,i suggest you get that intake fan from the bottom to the top and turn it the other side around (this might help in lesser dust collection into the case) so you get 2 intake and 2 exaust! That would work just fine 😉 hope it helped
