Fan Speed and Temperature???
Robilcorb
Hey all,
I have a Radeon X800GTO IceQ II Turbo 256MB GDDR3 PCI Express x16 Video Card. How do I change/view my fan speed? Also, how do I check the temperature?
Thanks!
ATitool is definetly recommended. If you play with the fan adjustments to raise the fan speed as the GPU temps rise, you can get your card to run considerably cooler. It also monitors your GPU temp with an icon in the system tray.
