Hello guys,
I've been encountering a problem for 2 days. My RTX 2060 FE (with no OC applied) under the workload of playing different games, now keeps hitting the 83 celsius threshold and going fan throttling every minute, that is very annoying. I exclude dust (as i keep it very clean) and airflow problems as before it usually worked under the 79 celsius limit. I've been experiencing this since a pesky windows update, the likely problem. Could be that there are any software conflicts that cause this thing?
I've updated the drivers and tried to contact Nvidia support, but they told me that it is fine till the 89 limit.
Please help me to figure it out what could be the problem here; I also attached GPU-Z screenshots, if needed.
Thanks
Specs
Sensors link
Thanks
Specs
Sensors link
