Hello everyone,
I got Gigabyte B450M-H motherboard.
Case - GEMBIRD midi-tower computer case Fornax K700 ATX black (It comes with 3 fans, each got 4 pins; and 1 fan with 3 pin ARGB).
The problem is that my motherboard is old and it doesn't have ARGB connection. Only CPU and SYS_FAN.
I have connected all my fans on SATA cable to the PSU (they work full speed, playing inside gets hot and loud).
Today I bought "Magnetic PWM & ARGB Fan Hub Controller (+5V 3Pin) 9 port SATA powered" - that was my mistake, because as I understood that this fan hub needs both connections PWM and ARGB to function.
I don't really care about RGB, I can live without it. But I would seek some recommendations what to do.
"Deepcool FH-04 fan hub" would let me connect 3 fans, but 3pin ARGB fan would work as single fan?
Or I should upgrade the motherboard to the newer one?
Hopefully someone understood me,
Thanks!
Thanks!
