G gomer68 Distinguished Feb 28, 2009 83 0 18,640 Mar 12, 2023 #1 Does anyone know if the fans on a msi nvidia geforce rtx 4080 ventus 3x overclocked , do they only turn on when needed? Thanks
X XxDarkMario20xX Distinguished Feb 3, 2016 1,821 282 20,940 Mar 12, 2023 #2 I owned an 3090 ventus card and they do come on there own when they reach a temp so most likely the 4080 will do the same because my 4080 MSI gaming tio comes on when they reach an temp! Reactions: gomer68 Upvote 0 Downvote
S sonofjesse Distinguished Jul 27, 2016 1,145 256 19,790 Mar 13, 2023 #3 Fans turn on when needed. I have a 4070TI, just watching youtube they do NOT turn at all 100% OFF/ZERO. This is normal on most video cards and power supplies these days. Just means they have good heat sinks Reactions: gomer68 Upvote 0 Downvote
K KyaraM Honorable Mar 11, 2022 1,712 793 11,290 Mar 13, 2023 #4 Most modern cards have a 0 RPM mode that prevents them from turning on until there is some load on the card. This one should be no exception. Reactions: gomer68 Upvote 0 Downvote
vladakv Distinguished Jan 26, 2016 249 38 18,640 Mar 15, 2023 #5 by default they're not spinning till some temp... you can change it on msi ab and set fan curve... soooo no worries. Reactions: gomer68 Upvote 0 Downvote
S sonofjesse Distinguished Jul 27, 2016 1,145 256 19,790 Mar 16, 2023 #6 We see this question a lot. Fans turn on when needed. Reactions: Order 66 and gomer68 Upvote 0 Downvote
G gomer68 Distinguished Feb 28, 2009 83 0 18,640 Nov 17, 2023 #7 Thanks for everyone's input ! Upvote 0 Downvote
