A couple weeks ago I made a post asking how to connect multiple fans to one system fan header and not have them run at full speed.
http://www.tomshardware.co.uk/answers/id-3731870/connecting-multiple-fans-single-fan-header.html
Gigabyte GA-B250M-DS3H
4 x 3 pin fans
Eventually I found this:
https://www.aliexpress.com/item/45cm-Fans-Extension-Power-Cable-Connector-4-Pin-Molex-Fan-Power-Cable-5x-PWM-4Pin-Fan/32849805448.html
It has 4 x 3 pins and 1 x 4 pin connector, the motherboard connector and a molex for power.
I now have all 4 fans connected and they're all running at full speed. I changed the control method to voltage in the BIOS, but none of the settings do anything. At least I can see the speed, which is something, I guess.
I disconnected the molex and none of them run, I guess they all get power exclusively from the molex.
I plugged one fan into the system header and it runs as expected, so that's not the issue.
I also tried to plug the CPU fan, which has 4 pins, into the cluster (maybe I have to use a 4 pin fan) but that still doesn't work.
At this point I don't know what to do.
Also, the 3 pin connectors I bought seem kinda weird, only 2 pins actually connect to the fan.
4 x 3 pin fans
