Hi all,
I am planning to buy BeQuiet Pure Base 500Dx case.
I plan to add extra fans to cool the pc nicely.
My idea:
The case comes with 3×14cm 3pin preinstalled fans. (One front,one top,one back.) I plan to put the top one on the front and buy two 14cm pwm for the top.
Is this going to be okay for good airflow or the two the top fans going to take the air away from the cpu cooler? So should be enough only one on the top?
The goal is:The two 14cm(3pin) front intake and the two top 14cm(Pwm) and the back one 14cm(3pin) exhaust(out).
My concern that is better to put pwm on the top instead of 3pin and front and back is okay to leave the 3pin fans.
And my last question: Should i buy the silent wings 3 or the pure wings 2 is good enough as well?
My config:
Cpu: I9 9900k
Cooler: Noctua NH-D15
Case: Be quiet Pure Base 500Dx
PSU: Seasonic Px850 Focus Plus Platinum
Memory: 3×16GB Kingston Hyperx Fury 2666mhz
Mobo: Gigabyte Z390 Aorus Master
SSD:1tb Samung 970 Evo
Hdd: Wd black 2tb 7200rpm
VGA: Msi Rtx 2080 Ti GamingX Trio
Thanks for your replies.
My idea:
My config:
Cpu: I9 9900k
