R RuffRidersEvo Distinguished May 10, 2014 151 1 18,695 Jul 20, 2020 #1 I just bought Far Cry 5 and the game is capped at 60fps, meanwhile i have a 144hz monitor and i even set the settings to “unlock the framerate” and turned vsync off in game and in the panel, but to no avail, Any help?
Solution boju Jul 20, 2020 Did you set the refresh rate to 144Hz under monitor in the game, where aspect ratio setting is? If you have, try disable fullscreen optimisation under compatibility for the game's launch app. Another possibility might be Xbox recording, if on with 60fps cap?
boju Titan Ambassador Jul 7, 2008 21,632 2,504 88,390 Jul 20, 2020 Solution #2 Did you set the refresh rate to 144Hz under monitor in the game, where aspect ratio setting is? If you have, try disable fullscreen optimisation under compatibility for the game's launch app. Another possibility might be Xbox recording, if on with 60fps cap? Last edited: Jul 21, 2020 Upvote 0 Downvote Solution
