Hm... Should i read between the lines then that, for 1440p, the 8GB VRAM is with the "normal" textures? So if you were to use the HQ textures, then the VRAM requirement would jump a lot, no?
Regards.
Well as I said it, "if I'm correct".
Now, with 1440 Far Cry 5 on Ultra settings on my rig, it really does,t even bothers me at > 120 Fps
Even with Far Cry 4 you had the choice to install HD textures as with Far Cry 5.
These days it just means more eye candy and more resource requirements.
But, if it will gain heavier graphics experience on my rig, of course I will install it.
I'm glad that one has the choice, compared with Call Of Duty where one has to load the ridiculous shader for ever, in which however does nothing to the game experience.
In my case, I will have install the HD-pack to be able to use my rig at the full extent.
GPU: ASUS TUF Gaming AMD Radeon RX 6900 XT OC 16GB
Extended monitor setup: Gigabyte AORUS-FI27Q27" 2560x1440 @165Hz, Philips IPS 24" 1920x1080 @60Hz
Mobo: Asus ROG Crosshair VIII Hero
SAM: Enabled and fully functional.
CPU: Ryzen 9 3950X
Ram: 16GB @3200 MHz
CPU Cooler: NH-D15-Se AM4
Storage: Samsung 980 Pro 2TB, Samsumg 950 Pro 1 TB
Temp: overall 36C deg.
