G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I do not have a long distance carrier, so I use a long
distance card. I have tried using the dialing rules as a
workaround to dialing the digits that I need to enter; ie
card telephone #, PIN # and FAX telephone without any
success.
I tried using the "calling card option" which requires
that I log in as a user to the FAX service. When I try
to log in, then stop the service to initialize it, it
gives me an "error 1069" when I try to restart the FAX
service. I even tried logging on as an Administrator
without success. All the knowledge based information
covers this problem for Windows 2000 with references to
policies and rights which does not apply to Windows XP.
1. Any suggestions to fix this logon situation or a
workaround using the dialing rules option?
2. Is there a way using the dialing rules to pause the
dialing process for a specific amount of time similar to
the calling card options? I tried inserting commas which
did not work.
success.
did not work.
