Hi there,
I have a 1GB/s Fiber Optic internet connection but the internet is not as fast as I would hope. Due to a high amount of signal loss in my apartment, the connection from my Asus router does not reach the bedrooms. Also, each mesh router does not recognize the other unless they are placed practically next to each other. I have an ultra-fast Lenovo X1 Carbon from work, an Intel i7 desktop, and an iPhone 11 on which I have run speed tests so this rules out the devices as an issue. I also have physical cables connecting each room (as you can see in the diagram below). The reason for such a setup was for FAST and RELIABLE internet, which did not end up delivering the results as intended. I have been using this configuration for the past two years.
I would now like to UPGRADE with advice from you all. I don't mind spending more money but want to future proof and improve it dramatically because I do a lot of work video conferences from my home office and have experienced dropped calls. I am looking for Wifi 6 (ax) and prefer just one Wifi network instead of multiple, though I don't mind a router & mesh combo.
Here's a simplified depiction of my 1,500 square foot apartment:
1. ROUTER: Given what you know, would you get a router + mesh combo setup, just router or mesh setup? My hunch says that a single router will not work because of signal loss. Routers or devices I am considering are (with prices from Amazon):
Thank you very much. I appreciate the help.
- As you can see, the Kitchen has the main fiber optic point and modem (Alcatel lucent g-240g-c)
- From the kitchen, there is a CAT7 cable that runs through the walls to the storage room where there is a router (ASUS Wireless N900 RT-66U Dual Band). The Router connects to four ethernet points (in the red box). Physical CAT5E cables then go to different rooms (master room, living room, bedroom, and the home office)
- Each room then has a Google Wifi (1st generation 802.11ac ) mesh router separately set up.
- NETGEAR Orbi AX6000 (it's very expensive though) - $999 for 3 mesh routers
- NETGEAR Nighthawk MK62-100NAS (reviews are not the best though) - $229 for just one router and one extender
- Linksys Velop WiFi 6 MX10 - $699 for two mesh routers
- ASUS Gaming Router Tri-band WiFi GT-AC5300 - $318
- TP-Link Archer AX11000 - $479
- TP-Link AC5400 Tri Band Gaming Router - $229
- NETGEAR Nighthawk X6S Smart WiFi Router (R8000P) - AC4000 $229 on Amazon
- AmpliFi ALIEN Router - $379 each
