Hi Peoples,
I have a Fiber router. My PCs are connected to it via wifi. I do not understand the tech or specs of what i need to improve my speed.
What type of connection do I have 5GHz/2.4GHz?
If I get an adapter that is a Wireless USB Adapter 5GHz/2.4GHz Dual Band 600Mbps, am I getting the correct one?
OR
Would this be better? AC1200mbps Plus High Speed Wifi Adapter Long Range 5G Dual Band External Two 6Dbi Wifi Antennas
Should I consider an extender that is compliant with 802.11ac with dual-band concurrent wireless?
Thank you for helping a newbie
OR
