Fifa 13 installation issue
Aayushbest
I am having problem installing fifa 13.After the setup completes 100% installation then cmd opens giving 10-12 same error lines-"xcopy is not a recognised ........................".After that i get the line in cmd - "Press any key to continue".After pressing any key cmd closes along with fifa setup.In the installed directory fifa 13 folder shows a size of 2.87 gb which means that it was not completely installed.Maybe cmd is unable to unpack the files on my windows 7 32 bit pc.The same setup file works fine in my friend's pc and fifa is installed completely with file size of around 6 gb.Do you think any stopped or disabled windows feature could be causing problems for unpacking?Please help and don't ask me where i got the setup from.
He's asking, because he is absolutely correct.
1. xcopy has nothing to do with installing fifa 13.
2. It was specifically identified in your other post that it is not a valid , legal version.
3. This is your one and only warning. Do not ask again.
Closing this.
