Archived from groups: microsoft.public.windowsxp.customize,microsoft.public.windowsxp.newusers,microsoft.public.windowsxp.perform_maintain,microsoft.public.windowsxp.setup_deployment (More info?)
Hi,
I saved my OE messages and settings using the XP files and settings transfer
wizard so I can put it back on my laptop after a XP clean install! That was
last night and I successfully saved the settings on 1GB SD card. I am
trying to transfer it to the Laptop and it asks my to insert disk #1, when I
click ok it says that this is not the correct disk! The backed up data are
on the SD card which is a file called "USMT2IMG"!
I used this wizard many times in the past but I always saved my stuff on a
hard drive partition and never had a problem with it! This time I used the
SD card but that is not working! Please help me get my data back, please!
The stuff I had on it is really hard to replace and would cost me a lot,
possible my job! Thanks in advance.
Hi,
