Final build analysis
Sonmitch98
88
You might have seen this build with slight variances. This is the final time I'm asking I have everything in cart. I'm just seeing if anybody will catch something that doesn't add up.
PCPartPicker part list: http://pcpartpicker.com/p/tZY6CJ
Price breakdown by merchant: http://pcpartpicker.com/p/tZY6CJ/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler ($25.99 @ Newegg)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($78.88 @ OutletPC)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1866 Memory ($64.99 @ Newegg)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card ($274.99 @ Newegg)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case ($38.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($75.98 @ Newegg)
Total: $802.81
Generated by PCPartPicker 2016-01-08 22:26
has been removed from shopping cart due to quantity limitation/insufficient stock. Some combo items might be affected by this. Is what it says when I add it too cart maybe because I'm on the mobile. I'll try and order it after I order everything else.
