Final Build,need help
JustCodyy
Commendable
May 16, 2016
36
I have a build,im adding a gtx 1080 in it when It comes,can somebody help me? I need to see to see if this is 1080p/1440p gaming worthy.http://pcpartpicker.com/user/Jess12/saved/#view=rPbWGX go to the fifth build
Not sure I understand the Mini-ATX board in the standard ATX Mid Tower.
I would probably opt for an M.2 compatible motherboard and an M.2 SSD.
There are better/cheaper and smaller power supplies that could power a single GTX1080. With that motherboard there isn't a possibility for a second.
There are nicer looking CPU coolers, though that one would work fine.
I would probably just go ahead and get Windows 10 so that you don'[t have to install Windows twice.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($339.99 @ B&H)
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler ($58.02 @ Amazon)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard ($119.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory ($66.98 @ Newegg)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive ($95.49 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case ($119.99 @ SuperBiiz)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($83.89 @ OutletPC)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter ($29.99 @ SuperBiiz)
Case Fan: Fractal Design HF14-BK 118.2 CFM 140mm Fan ($16.99 @ NCIX US)
Monitor: Acer XG270HU 144Hz 27.0" Monitor ($350.98 @ Newegg)
Total: $1506.64
Generated by PCPartPicker 2016-05-23 14:31 EDT-0400
Additional fans are not needed until you want to run SLI. PSU sized for GTX 1080 SLI if needed / desired down the road.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.89 @ OutletPC)
Motherboard: Gigabyte GA-Z170X-Gaming 5 ATX LGA1151 Motherboard ($139.99 @ Micro Center)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($49.99 @ Newegg)
Storage: Sandisk X400 256GB M.2-2280 Solid State Drive ($78.75 @ NCIX US)
Case: Fractal Design Define R5 Blackout Edition ATX Mid Tower Case ($94.99 @ NCIX US)
Power Supply: SeaSonic X Series 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($114.99 @ Newegg)
Total: $1260.95
It is an ITX motherboard with only 2 memory slots and one 16x PCIe slot. ...going into a mid sized case. Might as well go with a micro board or even a full sized ATX with that sized case. If you like the ITX motherboard, look toward ITX cases that fit long GPUs like the GTX 980 (1080). There are plenty out there...
Here are some coolers that are better than the H5:
The 850 EVO M.2 costs more than the SATA model, but it performs the exact same.
