Final Gamer Build - Will Order TODAY!
Raxus
102
Hey folks.
Final build here. Think this is pretty solid but wanted opinions once more before I order. Not really into OCing. One thing I would ask is..should I go with SLI mobo for future expansion or just wait a couple years and then build an SLI system then? Also should I go Vista or XP? Anyways here is the system:
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/product/product.aspx?item=N82E16811129021
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX
http://www.newegg.com/product/product.aspx?item=N82E16813128059
EVGA 512-P3-N871-AR GeForce 9800 GTX(G92)
http://www.newegg.com/product/product.aspx?item=N82E16814130339
PC Power & Cooling Silencer 750 Quad
http://www.newegg.com/product/product.aspx?item=N82E16817341011
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB
http://www.newegg.com/product/product.aspx?item=N82E16819115037
OCZ Reaper HPC Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
http://www.newegg.com/product/product.aspx?item=N82E16820227267
Seagate Barracuda 7200.11 ST3750330AS 750GB
http://www.newegg.com/product/product.aspx?item=N82E16822148298
SAMSUNG 2253BW Black 22" 2ms
http://www.newegg.com/product/product.aspx?item=N82E16824001268
SAMSUNG Black 20X DVD+R
http://www.newegg.com/product/product.aspx?item=N82E16827151154
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
http://www.newegg.com/product/product.aspx?item=N82E16835186134
Logitech X-230 32 watts RMS 2.1 Black Speaker System
http://www.newegg.com/product/product.aspx?item=N82E16836121123
$1506 @ Newegg
Looks good to me. Only thing I would change is the PSU as 750W is major overkill for a single-GPU system. Grab the 610W PC P&C and you're set.
I wouldn't worry about a 64-bit OS. You'll only lose 512MB of your RAM, and won't have to worry about compatibility issues. There may not be many, but none is better than few.
I would also go with the 8800GTS 512. Great card, and you'll save a chunk of change. Also, go with the 610W PSU. More than enough for a single GPU system. If you don't plan on OC'ing, stick with the stock cooler. No need for an aftermarket.
:non:
Go with 64 bit and have no regrets later. I have had no compatibility issues. If you do, a quick google usually leads to a fix.
Why spend 1000$+ on a computer and then use a 32 bit OS?
Also one note that I forgot, that samsung dvd drive has an ESSENTIAL firmware upgrade (if you copy dvds).
The drive is riplocked by default and will only copy css protected dvds at a maximum of 6x. CodeKing has found and removed this protection. You can find the firmware update at club.cdfreaks.com
I just built something very Similar, Just ordered it.
Looks pretty Solid to me.. I was toying with the idea of the 9800gx2, but its just not worth that much more money over an 8800gts, Maybe in a year or two I'll update it instead of spending that much for so little upgrade.
