[SOLVED] Finding A Card To Fit My Case
Nov 6, 2018
I'm looking to update my graphics card. I'm having trouble finding one to fit my case and motherboard. It's a custom built that I purchased off eBay.
Case: DIYPC Solo-T1-BK
Motherboard: MSI 760-GMA-P34 FX
CPU: AMD Black Edition FX-8300 Vishera 8-Core Socket AM3-Plus 95W
Current Graphic Card: Gigabyte Geforce GTX 1050 2GB GDDR5
From looking inside the case, I need a graphic card that height, which is 1.41. There doesn't appear to be much room between the components. I was looking at Gigabyte GeForce GTX 1070 Mini ITX OC 8GB GDDR5, but I'm not sure if it will fit. I know AMD is cheaper so if there is one that has roughly the same specs that would be great. I appreciate the help.
Thanks!
Thank you for your reply. The connectors for the front panel to the motherboard were a concern, too. The USB, audio and power button are all directly below the graphic card and, depending on the height, the SATA connectors would be in the way, too, which I did read I could find angled cables, but wasn't so sure with the front panel ones...
My PSU won't support it so I'm already looking at a few different ones.
I thought all PC cases were kind of a standardized size. My own case is a Fractal R 5. It's pretty nice.
Getting a bigger case is your only option cause the GPU isn't going to shrink. Compare the size of the GPU to the case.
