Finding the right GPU for first build.
Renegade47
I am nearing the end of my first build and I am having second thoughts on which GPU to run. I was initially going to go with the EVGA GTX 660 (Non TI). The alternative GPU i was considering is the GTX 750 Ti. I will mostly be doing all sorts of gaming, such as Day Z, ETS2, JC 2 and Titanfall. I have a budget of $225 for a GPU and i will be ordering the majority of my parts from Newegg Canada. My current specs (aside from the GPU) are the following:
CPU: Intel i3 4130 3.4GHz
Mobo: ASUS B85M-G (1150, PCI-E 3.0)
Memory: GSkill Ares DDR3 1600 2x4gb
PSU: Corsair CX500M 80+ Bronze (500w, 38A on 12V)
OS: Windows 8.1 Standard
Storage: WD Blue 500gb 7200rpm
Case: Cooler Master N600 (ATX Full)
So can you guys help me figure out which GPU would fit better with the rest of my build my build? I allready own the Mobo, PSU, Case and HDD. As a secondary question, Would an i3 4330 be better suited for gaming then the i3 4130. Is it worth the extra $15? This is my first time posting an this forum and my first time building a PC, so sorry if i broke any forum rule and thank you for your time.
