First Build, Compatibility Check and Possible Optimizations
Jack_281
Hello, I am looking to build my first PC and would like some advice on compatibility and possible optimizations. For reference, here is the basic rundown of what I plan to have in my build.
Motherboard: ASUS maximus ix hero
CPU: Intel i7 7700k
GPU: sli ASUS Strix 1080ti's
PSU: SeaSonic - PRIME Platinum 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
RAM: Corsair Vengeance LPX 32GB DDR4 DRAM 3200MHz C16 Memory Kit (4x8gb)
Case: Phanteks PH-EC416PSTG_BK Eclipse P400S Silent Edition with Tempered Glass
CPU Cooler: Phanteks U-Type Dual Tower Heat-Sink CPU Cooler PH-TC12DX_BK
SSD: Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD
HDD: Seagate SkyHawk 2TB Surveillance Hard Drive
OS: Windows 10 home 64 bit
PcPartPicker Link: https://pcpartpicker.com/list/YbQpkT
Please comment on any tips/advice/compatibility concerns you may have, I would appreciate it.
What use do you have in mind for this build? Seagate SkyHawk surveillance drives are designed for uses in which the majority of the disk operation is going to be writing, like in a DVR cameras setting, ideally something where the use looks like writing 90% of the time and reading the other 10%. The firmware is designed to prioritize handling write operations first and foremost. It's not a compatibility issue, however It may end up being inefficient if you need a balanced read/write setup.
If what draws you to the SkyHawk drive is the 24/7 operation rating, then another option which also has the 24/7 rating and is rated for the same 180TB per year usage, is Seagate IronWolf drives optimized for NAS. IronWolf drives have a more balanced...
I picked this cooler because it had decent reviews and fit the black/white theme of the build and fit in the case. I am open to suggestions for a different cooler that will fit inside the case.
If what draws you to the SkyHawk drive is the 24/7 operation rating, then another option which also has the 24/7 rating and is rated for the same 180TB per year usage, is Seagate IronWolf drives optimized for NAS. IronWolf drives have a more balanced read/write firmware, and are designed for uses when they may need fast access at any time of day, even from multiple users.
If you don't need the 24/7 rating and your use falls something more along the lines of traditional PC use/gaming, you may be better off (and potentially find a more cost-friendly fit) by going with Seagate BarraCuda HDD or FireCuda SSHDs.
If you'd like to check it out, here is a video which further explains choosing the right drive for the right application.
