There's seems to have been a hiccup with the mobile site. I did type out a long detailed post, then it asked me to write a description of the thread which turned out to be my first post. Where the other bit I typed has gone is beyond me!
So I'll start again.... Looong!
So, I'm almost at the point of putting together my first build. Aside from gaming this rig is going to be used for video editing, graphic design and some light 3d rendering. I don't plan on overclocking from the start, but I do intend to in a year or two. Also at the same time buying a second gpu to run in x-fire.
Here is the list of components:
http://uk.pcpartpicker.com/p/2UdWA
Now. Pc partpicker doesn't have the antec h2o 650 I've got, on their system so ignore the fact it doesn't have a cooler.... Or monitor, I've got it covered...
My question. The antec case has a rear exhaust fan that I plan on using with the radiator and it's own fan for optimum cooling. Only thing is the cooler auto adjusts the rads fan speed depending on cpu temp. The case exhaust has a manual switch on the back panel for speed adjustment. The psu I've got also has fan controllers. What would be the optimal setup??
I'll be documenting the actual build once the rest of my parts arrive so if interested stay tuned on pcpartpicker.
