First build for gaming ~900$
Stokburn
Commendable
Jul 19, 2016
Hey there.
I am looking forward to buying a PC next month. I've already chosen the components, however I am really concerned whether they are compatible with each other and whether I might be missing on something better. Also I'd like to hear some advice from experienced people in case there are indeed better/ more cost efficient options.
The PC will be used primarily for gaming (LoL and WoW mostly; at;1080p and nothing high end) However I want to know I am able to run the top games as well at least on med/high with reasonable FPS.
My budget is ~900$; ~700£; ~850€ as per current exchange rates (of course the cheaper the better)
motherboard: MSI H110M PRO-D LGA1151
HDD: 1TB SEAGATE 6G/7200/64M SATA
CPU: i5-6500 3.2GHz 6MB LGA1151
GPU: XFX RX 480 8GB Black RX480-M8BBA6
RAM: Corsair DDR4 2x8GB 2400MHz SODIMM CL16 Black 1.2V
SSD: ADATA SSD SP550 120G/SATA3 2.5 (might skip it; still undecided)
Cooler: CM HYPER TX3 EVO (I know it's not really necessary, but just in case)
PSU: be quiet SYSTEM POWER B8 550W 80 Plus BN259
Case: Thermaltake Versa H13 Window M-ATX Gaming Case (I am not nearly as sure about this)
not included in the budget
monitor: LG 24MP48HQ 23.8" LED IPS (cheapets I could find that meets my req: 24`` Full HD; IPS)
Any feedback will be much appreciated.
P.S. I am from Bulgaria and will be ordering the PC from a local vendor, because I lack the ability to build it myself. Although the choice is pretty rich majority of components are also limited. (mostly the case and PSU)
