First Build Help needed
Zaync
7
Hi,
This is my first build, i am not going to be gaming, just need something which will last, which will be relatively fast with multiple high memory using apps running in one go like, photoshop, fireworks etc and watching HD movies. My budget is £500, this is the part list i have compiled so far, it is coming to £597, need some help on how i could get this down to £500 and also if everything i have picked is compatible or not.
CPU: Intel Core i5 i5-4690K CPU (Quad Core 3.5GHz Processor 6MB Cache, Intel HD 4600 Graphics, Socket H3 LGA-1150)- £167.50
GPU: Palit 2GB Nvidia GeForce GT 630 Graphics Card - £44.98
RAM: G-Skill 8GB Ripjaws X DDR3 2133 Dual Kit - Red- £73.58
MOBO: Gigabyte Z97X-SOC INTEL LGA1150 Z97 ATX Motherboard (4x DDR3, 6x USB3.0, 6x USB2.0, GBE, LAN, HDMI, DVI-I, DP, DSUB)- £100
HDD: Samsung 840 EVO 120GB 2.5 inch Basic SATA Solid State Drive - £54.58
PSU: Corsair Builder Series CX 430 Watt - £34
Case: Coolermaster Storm Enforcer Mid Tower ATX Case -£63
Other:
Samsung 24x SATA DVD Writer - Black -£13.45
Arctic Cooling MX-4 4g Thermal Compound £4
Cooler Master Hyper 212 EVO (120mm) - £27.24
CSL 3.5" all-in-one USB 3.0 (Super Speed) card reader | 2 x USB 3.0 | Multi-function panel in black | SD / SDHC / Mini SDHC / Micro SDHC / USB / XD / CF / MD - £14.85
Thanks
Looks great. I would however advise going with the Samsung SSD over the sandisk. Benchmarks lean strongly to the samsung over any other brand at the moment. 840 or 850 series are all good, whichever is cheapest is a great buy
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£130.94 @ Aria PC)
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard (£58.18 @ Scan.co.uk)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory (£57.99 @ Amazon UK)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive (£54.95 @ Aria PC)
Video Card: Gigabyte GeForce GTX 750 2GB Video Card (£89.99 @ Ebuyer)
Case: Corsair 300R ATX Mid Tower Case (£54.99 @ Amazon UK)
Power Supply: SeaSonic 360W 80+ Gold Certified ATX Power Supply (£53.58 @ Amazon UK)
Total: £500.62
Generated by PCPartPicker 2014-11-24 23:58 GMT+0000
Well, the thing is, since you're not gaming the unlocked processor and motherboard has significantly less purpose. Ergo I downsized the processor to a smaller stock clocked haswell i5 that should handle all your tasks with relative ease. I did bump your graphics card up a bit, to accommodate your needs better. It could, given you had a sudden urge to, do some light gaming.
If you wanted something a little more in the processor area, I'd suggest a 4590 with the same motherboard. More performance and better single core than the 4460.
I won't ever be gaming.
I want a future proof processor.
what do you think about the GPU i chose? are there better alternatives that can be purchased for around £50?
is everything i mentioned in original post compatible?
i've changed it up a bit, taking up your feedback, how does this look?
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£131.99 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£24.97 @ Amazon UK)
Motherboard: MSI H97M-G43 Micro ATX LGA1150 Motherboard (£66.99 @ Amazon UK)
Memory: Crucial Ballistix Sport XT 8GB (1 x 8GB) DDR3-1600 Memory (£59.99 @ Amazon UK)
Storage: Sandisk X300S 128GB 2.5" Solid State Drive (£74.01 @ Amazon UK)
Video Card: Asus GeForce GTX 750 Ti 2GB Video Card (£106.99 @ Amazon UK)
Case: Cooler Master Storm Enforcer ATX Mid Tower Case (£88.38 @ Amazon UK)
Total: £606.90
Generated by PCPartPicker 2014-11-27 03:01 GMT+0000
could i not go with the cheaper corsair builder power supply?
any decent cheaper gpus? around £60-70?
whats the best motherboard for around £60-£70?
