I have ordered most of the parts except the CPU, Mobo and the case. I will be using this PC just for surfing the Web and gaming. Hopefully it is good enough that I can run games like Rust, League of Legends, and Minecraft.
So these are parts I chose, hope the parts I've already bought aren't bad.
CPU - I went with the AMD FX 6300, I thought this was the best bang for the buck for my budget.
Mobo - I have my eye on the M5A97 R2.0, but I'm not sure if I'll get that or the Extreme 3 or even the M5A78-L.
GPU - After much headache and over thinking, I chose to go with the Gigabyte GTX 660. I was either going to pick this or the 7850. But due to the better ratings/reviews and the better performance at stock I chose to go with this card.
Memory - I bought the G Skill Ripjaws X Series 2x4 SDRAM 1600. I'm actually not sure what SDRAM is but hopefully this is a good memory.
Hard drive - 1Tb Western Digital Blue
Optical drive - $17 DVD-ROM
Power supply - Corsair CX 500 Modular 80 bronze. I think this is enough power for my build.
Case - undecided.
So overall, How did I do? I'm very excited on building this. It should be an upgrade over my current build 😀
Current Build -
I5 2430M 2.3 or 2.4ghz laptop.
Interpreted Hd3000 graphics
4 Gb DDR2
125Gb Hard drive
Case - undecided.
Current Build -
4 Gb DDR2
125Gb Hard drive
