First Build. Need Advice
Your CPU is socket 1155, but your motherboard is socket 1150. You would need to either get the 4670k or a different motherboard. Other than that, the parts look fine to me. You don't need that big of a power supply though, unless you plan to SLI the 770 in the future.
pcpartpicker.com
Plz make a list of parrs on this site or write them down. Opening 10 links is quite a lot of work to check out some speca. It would increase the chance of ppl looking.
This one would be ok???
Intel Core i5-4670K Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I54670K
what is the difference between i5-4670K Haswell and i5-3570K Ivy Bridge
Sli is when you run 2 or more NVidia cars in one system. For amd Its called CrossFire.
And I didnt say the cpu and mobo dont match or did you find it out your self?
Cuz I am not going to open 10 links on my tablet. That'll be chaos.
Here you go, $150 under budget and is fully compatible:
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($219.99 @ Newegg)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($97.16 @ Amazon)
Motherboard: ASRock Z87 Pro4 ATX LGA1150 Motherboard ($99.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($64.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Newegg)
Video Card: Asus GeForce GTX 770 2GB Video Card ($332.99 @ Amazon)
Case: Corsair 500R White ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($65.99 @ SuperBiiz)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($14.99 @ Newegg)
Total: $1056.08
(Generated by PCPartPicker 2014-02-24 12:56 EST-0500)
The architecture. The 4 in 4670 shows its a 4th gen cpu, and the 3 in 3670 means its a 3th gen. So the 3670 is just not their newest generation, but that doesnt mean its bad. Still id get a latest gen one if younbuy something anyway, prices are close to equal as far as ive seen.
Here is what I bought
Optical Drive: Asus 24x DVD-RW Serial-ATA Internal OEM ($23)
Power Supply: Corsair CX Series 750 Watt ATX/EPS Modular 80 PLUS Bronze ($75)
CPU: Intel Core i5-4670K Quad-Core Desktop Processor 3.4 GHZ 6 MB Cache ($210)
RAM: Corsair Vengeance Pro Series 8GB 2 x 4GB DDR3 1600 ($84)
CASE: Corsair Carbide Series White 500R Mid Tower ($128)
HDD: WD BLACK SERIES WD1003FZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s ($90)
GRAPHIC CARD: EVGA SuperClocked w/ ACX Cooling 02G-P4-2774-KR GeForce GTX 770 2GB 256-bit GDDR5 PCI Express 3.0 SLI Support Video Card ($340)
MOTHER BOARD: ASUS Z87-A LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel ($140)
Cooler Master Hyper T4 - CPU Cooler ($30)
