So this is the build I'm looking at getting. I know it hasn't got a GPU on it yet as i cant find the one I'm going to be using its a radeon r9 360 2GB, (a friend is giving it to me until i can afford a decent one, this should fit/run with this build?) With that in mind I am looking for advice on a GPU, I know this isn't the place I want to cut corners on so I don't mind spending a bit more on this, £180-£240. Ideally 1060 6gb+, I have had a few friends say to stay away from radeon as they dont get on with the software, (guess i'll be able to test for my self in the meantime). The motherboard I'm unsure on as im tempted to get the MSI B450 Tomahawk MAX instead as It's 3rd gen ready but it a a bit more expensive and as far as I'm aware I will be able to update the BIOS on this one? I don't have access to an older CPU though is that an issue or can i not upgrade the BIOS via a flash drive?(any advice/info on this would be greatly appreciated). Everything i've picked has been with budget in mind, whilst wanting to build a system that will last me a few years without having to upgrade everything in one chunk. Is there anything with this build where I need to upgrade/improve or where I can cut cost on something to allow improvement elsewhere.
https://uk.pcpartpicker.com/user/connor_cmt/saved/r8MykL
