First build, Need some help here
itsgreekpete
18
Hey guys, just looking for someone to review my build here. I'd like to stay under 1500. The 5930k is already ordered, so that wont' be changed. I will be using the build for gaming, making games (hopefully), music production, and coding. I do plan on addint another 970 in the furure. Any recommendations/changes are welcome :). Or if it's fine as is, I shall order!
PCPartPicker part list: http://pcpartpicker.com/p/VR9PYJ
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor ($221.52 @ Intel Retail Edge)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($104.99 @ Amazon)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard ($234.99 @ Amazon)
Memory: A-Data XPG Z1 8GB (2 x 4GB) DDR4-2400 Memory ($151.99 @ Amazon)
Storage: Crucial MX100 512GB 2.5" Solid State Drive ($168.00 @ Amazon after applying points)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($58.03 @ Amazon)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($369.99 @ Amazon)
Case: Cooler Master HAF XB EVO ATX Desktop Case ($86.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($21.69 @ Amazon)
PSU: Cooler Master V750 (109.99 @ Amazon)
Total: $1441.19
Looks good, it is a huge overkill CPU but for that price!!! wow!
If you are doing a lot of music production you might benefit upgrading to 16GB of RAM.
But you don't need such an expensive high clock speed one, you won't really see the difference.
You can snatch 16GB for the same budget that will perform almost identically.
SproutSchon
620
SproutSchon
620
No reason to get the x99PRO unless you are planning to use 3300MHz RAM (lol).
You sould consider the Fractal Design R5 or the Nanoxia Deep Silence 1.
Both provide quiet computing and great airflow.
I have the R4 (the R5 just got with some slight improvements) and I am super happy with my choice.
