first build please help!!!
jupacshalom23
16
Im really looking forward to building my first gaming pc, but i don't know anything. If somebody could take a look at my pcp profile and let me know of anyways i could streamline to lower cost without reducing performance? Also a good case/power supply combo. Lastly i have a wireless router so i probably need a wireless network adapter, the list of which i was very confused by, any suggestions or info on that would be appreciated.
Here is my build http://pcpartpicker.com/user/jupacshalom23/saved/2ycgXL
edit: also not sure if i picked a good video card, or if the sapphire 290, or powercolor... it's alot, i have no experience so any help would be appreciated, also if ill be okay with the mc 212 evo cooler. As far as cases i was looking at the cm cosmos se.
i could go less on cpu more on gpu, also i was actually going amd because i plan on getting gta 5 and they have some kinda thing with amd's mantle, blu ray occasionally so i like to have ability, and as far as the case i'm just asking for suggestions, i was leaning toward cm cosmos se, but if you have a suggestion for a better case let me know, and thanks for all the info.
edit: sorry i missed that the budget is say 2000 but flexible
Here is my suggestion for a single 1080p or 1440p monitor:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($209.99 @ Amazon)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($69.99 @ Amazon)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($205.98 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($78.30 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($109.99 @ Micro Center)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($79.99 @ NCIX US)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card ($349.99 @ NCIX US)
Case: Cooler Master COSMOS SE ATX Mid Tower Case ($119.99 @ Micro Center)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($119.99 @ NCIX US)
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer ($43.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($87.98 @ OutletPC)
Wireless Network Adapter: TRENDnet TEW-805UB 802.11a/b/g/n/ac USB 3.0 Wi-Fi Adapter ($16.99 @ Amazon)
Total: $1493.17
Generated by PCPartPicker 2014-09-10 11:30 EDT-0400
If you want a water cpu cooler then the Swiftech H220X is an option.
http://pcpartpicker.com/part/swiftech-cpu-cooler-h220x
1920 by 1080 i believe, i like to play on ultra settings for skyrims and stuff if i can, fps once in awhile and i don't play mmos or anything that intensive
that looks pretty good and lowers the price alot, but if i had my heart set on amd parts how would you build something on par with amd cpu and gpu.
edit: oh and i was looking at that windforce card maybe i'll go for that thanks!
Only the cpu and motherboard would change:
http://pcpartpicker.com/p/4Tph23
that looks good! you don't think its worth going for 2 8gb ram sticks?
No,multitasking should be fine. Opening multiple tabs in chrome should be fine.
