First build : questions
Oleonius
448
I have some questions about computer hardware. Here is a possible configuration that I look at to buy on Newegg.ca soon !
Case: Azza Solano 1000
Processor: Intel Core i5 2500k (3.3 GHz)
Motherboard: ASRock P67 EXTREME 4
GPU: MSI N560GTX-Ti Twin Frozr II O/C
Power supply: Silverstone Strider Plus 750W
HDD: WD Caviar Black 640 GB
Memory: Kingston HyperX 2x4 GB DDR3/1600 MHz
So, my questions are :
1. How do you find this gaming rig ?
2. Is the Z68 chipset worth getting ? I hesitate between this ASRock P67 EXTREME 4 and a ASUS P8Z68-V PRO !
3. Do I need extra fans ?
Thanks you 😉
I'd down on the AsRock boards because they don't offer an industry standard 3 year warranty .... just recently they bumped it up from 1 to 2 years but 3 is the industry standard.
For the price of the Azza you could have one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129097
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
They have plenty of fans. Yopu willw ant a CPU cooler if overclocking
Cooler - $40 - Scythe SCMG 2100 http://www.newegg.com/Product/Product.aspx?Item=N82E16835185142
TIM - $5 - Shin Etsu http://www.newegg.com/Product/Product.aspx?Item=N82E16835150080
I'd take the 900 MHz Asus or EVGA over the 880 Mhz MSI
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130651
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121425
I have gotten most of the Asus ones to 1000Mhz w/o any voltage adjustments
Current Strider is not a bad PSU w/ 9.5 rating
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=183
But at $180, I'd opt for the same 9.5 rating from an XFX Core Edition for $85
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207015
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story10&reid=216
The 640 GB model is a bit slow .... Spinpint 1 TB is just few $ more
