[SOLVED] First build rookie
Dec 30, 2018
4
Specs are as follows:
Asus Prime X370-A motherboard
AMD Ryzen 5 2600 cpu
Wraithcooler on the cpu
Corsair Vengeance LPX 16 GB (2x8) 2400
Radeon Sapphire R9 270X GPU
2 blue LED front fans (case default 120mm)
1 120mm back fan
CM Elite V3 500W PSU
Ive got the required PSU cords connected to the correct spots (CPU, MOBO, GPU, Fans, SSD). The PC turns on when the power button is pressed, but i dont get any beeps from the case speaker and no display to a monitor or TV. Any recommendations to help a rookie?
Yes I agree most likely you'd need to update the BIOS. Which you can't do without a 1*** series processor. Need a b450/x470 board
