First build! Skylake $800
Double Rubber
Commendable
Mar 20, 2016
12
My first build! Just trying to make something that can handle 1080p @60fps minimum without issue and be a solid foundation for upgrades throughout the year.
Approximate Purchase Date: This week
Budget Range: $800 +/- $20 and preferably before rebate
System Usage: Gaming
Preferred Website(s) for Parts: Amazon
Overclocking: CPU - no. GPU - maybe
SLI: In the future
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($196.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard ($118.98 @ Newegg)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2400 Memory ($34.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($317.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case ($63.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($34.99 @ NCIX US)
Total: $813.82
Generated by PCPartPicker 2016-03-20 20:16 EDT-0400
Pretty much nailed it, but I would use a Seasonic S12II 520 over the EVGA 500, better quality. Might also want to use a kit of RAM rather than one stick for dual channel. I may be picky, but I can tell the difference. System doesn't feel as "crisp" when in single channel mode. Consider getting a 750 watt PSU now if you intend to go SLI rather than buying the PSU again.
Memory: G.Skill NT Series 8GB (2 x 4GB) DDR4-2133 Memory ($32.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($48.99 @ NCIX US)
Total: $825.82
Generated by PCPartPicker 2016-03-20 20:29 EDT-0400
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory ($36.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0+ Video Card ($309.99 @ NCIX US)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case ($44.99 @ SuperBiiz)
Power Supply: Antec TruePower Classic 750W 80+ Gold Certified ATX Power Supply ($54.99 @ Newegg)
Total: $808.82
Generated by PCPartPicker 2016-03-20 20:30 EDT-0400
dual channel RAM kit , power supply that can SLI two GTX 970's
micro-atx option, and it has CPU overclocking capability if you change your mind later.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($112.99 @ SuperBiiz)
Motherboard: ASRock Z170M Extreme4 Micro ATX LGA1151 Motherboard ($118.98 @ Newegg)
Memory: G.Skill Aegis 16GB (2 x 8GB) DDR4-2400 Memory ($59.99 @ Newegg)
Storage: OCZ Trion 100 480GB 2.5" Solid State Drive ($109.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0+ Video Card ($300.80 @ Newegg)
Case: Enermax ECA3212-BL ATX Mid Tower Case ($24.99 @ Newegg)
Total: $776.73
Generated by PCPartPicker 2016-03-20 20:44 EDT-0400
Awesomely ideas! I'll definitely switch to dual-channel ram (2×4gb). I should have mentioned before that I'm pretty set on the S340 case for the asthetics, but thanks for all the great options!
Also, is there really any big differences between the Gigabyte Z170XP-SLI and the MSI Z170A SLI Plus?
