First Build Troubles
LizardWizard
5
I got everything hooked in and it's all turning on and running but my monitor still says No Signal. My motherboard supports both HDMI and DVI-D. I've tried both and still nothing. I unplugged my graphics card and tried again and still nothing. This is making me crazy! What am I missing/doing wrong???
Most probably the board needs a BIOS update for supporting the Kaby. With that board you can order a BIOS chip on ebay and replace the board's one. Or, AsRock might send you one if contacted, or a local pc repair shop might help.
ASRock MicroATX Z170M Extreme 4
Intel i-5 7500 LGA 7th gen
Gigabyte Radeon RX 480 GPU
Crucial MX300 275GB SATA SSD
WD Blue 1TB Hard Drive
500W power block
16GB RAM HyperX Fury
