First Built
daman246
15
Hey guys im new to the site and new to the whole COmputer World you guys are in so i need a little help My budget is 600 excluding Monitor,keyboard,mouse
The computer will be used mainly for Programming and FOr Gaming
GPu- Radeon 5770
CPu - AMd Phenom X6 1090t
MOBO- ASUS M4A88TD-V EVO
PSu-600 or 650 watt Corsair,Antec,OCM
Ram- Corsair 8Gs DDR3
Case- Cooler Master Elite Mid Tower Case, RC-310
HDD- seagate 1TB
So guys have any advice on how to lower my COst or Increase my performance,
And to make sure everything iS compatible im really new to this
Couldnt find a better case 🙁
Most of these items are gonna be bought through Amazon
^ CASE - Check out the NZXT Gamma, though it comes with 1 stock fan, but is well ventilated with options to add more fans,...
RAM - This is cheaper
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148347
PSU - Again this would be cheaper but good enough
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
Or you could even get the Antec Neo ECO or Antec HCG 520W, as you will be sticking with 1 graphic card,...
CPU - Get the 1090T and save money as it is basically the same chip but clocked just a bit lower, also has unlocked multiplier,...
Graphics card - This is pretty cheap - HD 6770 - A rebrand of the 5770
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102941
