Okay I have been viewing tutorials around the web learning (hopefully) the basics of building a computer starting from scratch. I'm on a budget, of about $1000 NZD (approx $880 USD, $550 UKD). Be warned that this will be my first build, I have some experience in practicals of assembling so that should be alright.
So my AIM for the desktop computer:
That can handle at least minimum requirements for games such as Rome Total War 2, because I'd enjoy playing some strategic games here and there. I will use this computer for study which I guess falls to low end work such as word processing and programming using Java.
Parts I am considering at the moment:
- Intel Core i7-4790 Haswell Quad-Core 3.6GHz LGA 1150 84W Desktop Processor Intel HD Graphics 4600 BX80646I74790 {$360NZD}
(I actually was gonna go with 4790K but I am quite new to how overclocking works at this stage so I avoided it)
-ASUS Z97-A LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard{$165NZD}
(I specifically chose a Z97 chipset because apparently the CPU chosen only works with this, referencing this off reviews by the way, because I'm pretty sure you can do something to the BIOS but I don't know too much about it)
-CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9{$105.00NZD}
(I was going for a 4GB but like apparently the inbuilt graphics card (HD 4600 by the way) on the Chosen CPU partitions some of your memory I found)
-I'll get some sort of HDD (1TB){$80NZD}
-GPU inbuilt processor (HD 4600)
-I'll find a case somewhere I think I'll go with a Full Tower{$100NZD}
-I believe a 550W power supply should suffice, please let me know if there is a problem with my PSU in particular as in how much power does this need.{$150NZD?}
I choose in that following order too by the way, the reason for a crazy processor is just because of me... Maybe I have this compulsion to get a more powerful CPU
I don't know.
Screen and mouse etc.. to include in budget too. So maybe a lil over my budget, but that is alright.
THANKS HEAPS AND HEAPS
![Smile :) :)](/data/assets/smilies/smile.gif)
