First Gaming PC Build Parts List/ need CPU
Firedroid2
13
Hi there, I am planning on building my first gaming PC and my main focus is performance. I am planning on using this almost entirely for gaming, and possible some photo video editing. I had everything picked out of PC part picker, but recently the cpu I as planning on using was not for sale. I have attached a link to the parts list, as well as copied and pasted what it says below. If anyone has any other suggestions in changes, that you are sure are comparable, please tell me (such as if I should go with 2 4g sticks of RAM or more/ if something is not compatable). Thanks!
(I am new to the site, so if this is in the wrong section, sorry)
Here is the link to PC Part Picker:
http://pcpartpicker.com/p/2omLE
CPU Cooler
Noctua NH-D14 65.0 CFM CPU Cooler $78.99 FREE $78.99 Amazon
Remove
Buy
Eligible for free two-day shipping with Amazon Prime membership
Motherboard
Intel DP67BGB3 ATX LGA1155 Motherboard $89.95 $5.93 $95.88 Amazon
Remove
Buy
Memory
Corsair XMS3 4GB (1 x 4GB) DDR3-1333 Memory $64.99 -$20.00 FREE $44.99 Newegg
Remove
Buy
$20.00 mail-in rebate
Remove
Buy
Add Additional Memory
Storage
Samsung 840 Pro Series 128GB 2.5" Solid State Disk $132.99 FREE $132.99 Mac Mall
Remove
Buy
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive $89.48 -$5.00 $84.48 OutletPC
Remove
Buy
$5.00 mail-in rebate
Add Additional Storage
Video Card
Asus GeForce GTX 660 Ti 3GB Video Card $259.99 $6.99 $266.98 SuperBiiz
Remove
Buy
Add Another Video Card For 2-Way SLI
Case
Cooler Master HAF X Blue ATX Full Tower Case $204.99 $11.99 $216.98 Newegg
Remove
Buy
Power Supply
PC Power & Cooling Silencer Mk III 750W 80+ Gold Certified Semi-Modular ATX Power Supply $149.99 FREE $149.99 Amazon
Remove
Buy
Optical Drive
Pioneer BDC-207DBK Blu-Ray Reader, DVD/CD Writer $49.99 $5.44 $55.43 Amazon
Remove
Buy
Add Another Optical Drive
Operating System
Microsoft Windows 8 (OEM) (64-bit) $97.98 $97.98 OutletPC
Remove
Buy
Monitor
Asus VS247H-P 23.6" Monitor $159.99 -$30.00 $4.99 $134.98 Newegg
Remove
Buy
+ $10 off w/ promo code EMCWVVX87, ends 12/26
Keyboard
Razer Blackwidow Ultimate 2013 Wired Gaming Keyboard $119.99 $9.99 $129.98 SuperBiiz
Remove
Buy
Expansion Cards / Networking
Add Expansion Cards / Networking ...
Sound Cards, Wired Network Adapter, Wireless Network Adapters
Thanks to anyone who helped!
http://pcpartpicker.com/p/2rwUl There are a lot of good things I choose for you for this build. I gave you the new i7 4770k and it comes with a cooler master 120m water cooler which will fit in you case for sure and will keep your pc cool. Also, if you do plan on to overclock later on, you can do that with this water cooler. For the motherboard I gave you the gigabyte z87x-oc. This is by far one of the best motherboards for overclocking I have seen, just look at the features that it gives you http://www.newegg.com/Product/Product.aspx?Item=N82E16813128594&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
You have 16gb of corsair vengence pro ddr3-1866 and the thing is that it is only 2...
Fist of all their are a lot of problems with your build. If you don't mind, could you please tell me your budget for this build so I could make your build the best it can be within that budget. Also be sure to let me know if their is a certain product in the build you must have.
Hi there, I am trying to keep it roughly around $1500, but would be willing to go a bit over. I know that it takes money to get the kind of performance I am trying to achieve, but don't want to go crazy. Basically I just chose everything based off of different forum posts, and the only thing I want to keep with it is the case. Also, I am not planning on overclocking any time soon, but still want something that would make it possible in the future, without too many upgrades. Thanks!
You have 16gb of corsair vengence pro ddr3-1866 and the thing is that it is only 2 modules so if you want later on, you can upgrade it even more. For storage, you have Samsung 120gb ssd and a Western Digital 1tb hard drive. For the graphics card, you have a gigabyte geforce gtx 760 with 3 fans for ultimate cooling. The case is the same as you chose in your build, and for the power supply you have a cooler master 700w 80+ Gold FULLY MODULAR power supply and you have a blu ray reader and writer. I did go for a blue color scheme because of the case. If you have any more questions, please let me know.
Thanks for the info! One last question, if I was using that build, would I need to get an adaptor to get to internet? I already have wifi in my house, but am considering getting Ethernet for faster gaming. Is it already able to use Ethernet/ Wifi, or will I need to add adapters to the build?
Whenever you want to use ethernet, you never have to worry about adapter. Yes, if you do want to connect with wifi, you will have have to use a wifi adapter that is usually usb powered. I wouldn't recommend using wifi because you will not get slower internet than you would with ethernet.
Read the specs on the Motherboard
