First PC Build ever and I need help
Sebastian13
Commendable
Jun 18, 2017
24
I just finally bought all the parts I need for my computer that I have been saving up for 2 years now and once I finally put it all together the computer will turn on (I think) the fans at the back turn on but nothing shows up on the screen and no other fans turn on. It's a really REALLY confusing case with lots of wires that I have no idea where they go can someone please help me.
I can send pictures of the build so you can see if I connected some things wrong or something and my specs are as following:
CPU: i7 4790 (Used) but works fine on another computer
Motherboard: MSI - H97 PC MATE
Ram: G.Skill - Ripjaws X series 8GB (2 x 4GB)
Storage: Western Digital - Caviar Blue 1TB
GPU: Gtx 1050 TI mini
Case: DIYPC - Skyline-07 R ATX Full Tower Case ( Bunch of weird fan cables I need help with please!)
Optical Drive: Asus - DRW-24F1st DVD/CD Writer
Sebastian13
Commendable
Jun 18, 2017
24
well it didn't work but I did get the system to stay turned on but nothing shows up on my monitors my keyboard and mouse both light up when I plug them in so the motherboard isn't broken or anything I literally have absolutely 0 idea what to do please help
Sebastian13
Commendable
Jun 18, 2017
24
Well I got the computer working I installed Windows and all but the problem was that I plugged my hdmi cable into the motherboard instead of the graphics card so I can only use one monitor now on my computer it's very annoying if you know how to fix this please reply because I am so used to 2 monitors it is very frustrating using only one after a very long amount of time using two
Sebastian13
Commendable
Jun 18, 2017
24
I have to enable the 2 monitors in my bios? and I don't have a vga port on my graphics card that is why I am only using one monitor because my second monitor only has vga and dvi but it's still 1080p so its all goodd
Sebastian13
Commendable
Jun 18, 2017
24
My screen turned on perfectly for maybe 4 seconds and then the whole screen went really green like I could still see what was on my screen but it was realllllly reallly green. Do you know why this is and how to fix it?? or is the whole monitor toast?
